RTE compatibility
Is it real that we cannot run a compiled lv9 application under L10 RTE ?
LV RTE is not retro compatible ?
that means for a client to install each version of RTE if he has applications of  differents versions...
Is it planned with futur versions to make it retro compatible ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,629 Views)
Yes, you need to install the correct runtime for each built application.
(Each run-time version only supports applications built in the matching version.)
Easiest is to include the correct run-time engine with the installer.
(2,626 Views)
Regards
Tinnitus
Tinnitus,
this is often requested, but i don't know if this is going to happen. But since even Microsoft is not providing full downward compatibility in their .NET Framework, it shows that Runtime Engines are not *simple* and most often, it is easier to supply a runtime engine for a single version of code only.
So please follow altenbachs suggestion to use the application builder for creating an installer which includes the appropriate RTE.
thanks,
Norbert
Norbert
Expert: Geometry
(2,623 Views)
