RTE LV8.5 and RTE LV2013 with cDAQ can work together?
Hi:
I have a labview exe file in 2 versions. LV8.5 and LV2013
And for this exe files I use cDAQs
Can I install both RTE and cDAQ drivers and both exe files correctlly?
I have cDAQ driver version 14.2.0 for LV2013 and NIDAQ922f0.exe for LV8.5
Do I have to do any special? Any trick? Will they work ?
I need to do this because LV8.5 file is completelly tested and I can trust in this, but new file LV2013 will be in evaluation and in case of problem I can easilly go to safe version.
Please help
(2,972 Views)
Windows does not allow for more than a single hardware driver to be installed. I don't believe there is a version of DAQmx that is compatible with both versions of LabVIEW.
(2,966 Views)
