RTDX problem after restart Labview program
I've created Labview code that reads a RTDX channel from my TI 6000 DSP together with the high speed RTDX emulator. That works very well. I can read data with no limitations. When I stop my LabView code, I close the CCS
Problem occurs when I stop my Labview code and restart it again. I get data from RTDX only a few times at the beginning, and afterwards nothing anymore. The Read VI tells there is no data anymore. I know for sure the DSP is still sending data over the RTDX. To solve the problem I have to restart CSS and labview again.
What can be the cause of that and what is the solution? Do you know this problem?
(2,921 Views)
what is your high speed RTDX emulator??
(2,865 Views)
