RT thermography image processing
Hi there,
does anybody have experience with Labview RealTime and thermography or RT and Imge Processing in general?
What hardware do you use? What are the advantages or disadvantages?
I am about to build up a system for thermography and i am looking for hardware to use.
(3,205 Views)
We are using a couple of FLIR cameras for thermography, but not with RT hardware.  I purchased the FLIR LabVIEW toolkit, which simplified the programming.
Why are you needing RT?  Won't you be limited by the frame rate of the camera?
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,187 Views)
Jesus loves you vt92
I am using an A320 camera. The camera already shot lot of  *.fff images. How do I open and process the images in Labview vision software? Does the Flir labview tool kit has a VI that can converter *.fff image to the format that Labview vision can access?
I am looking forward to getting your advice.
Kind Regards
Hong
(2,777 Views)
