RT Standalone and FPGA Access
the question is how can i access the FPGA from my Standalone RT System?
Im trying to build a standalone rt application on my desktop RT system.
Since now im running the FPGA via "Reference" from RT.
If i try to build the Standalone Application, i get an unspecific error with error message "Data not found,...".
Error Message:
Fehler 7 bei AB_Engine_HandleLinkErrors.vi -> AB_Engine_Update_Source_from_Linker.vi
Mögliche Ursachen:
LabVIEW:  Datei nicht gefunden. Die Datei befindet sich evtl. an einem anderen Speicherort oder wurde gelöscht. Prüfen Sie mit Hilfe der Kommandozeile oder des Datei-Explorers, ob der Pfad korrekt ist.
NI-488:  GPIB-Schnittstelle existiert nicht.
Therefore I am not using any GPIB Interface and the RT VI is definetly in the right folder.
Greetings,
Ben
Message 1 of 9
(3,896 Views)
Hi Ben,
which kind of hardware do you use?
Which "desktop RT system"? Which FPGA?
Message 2 of 9
(3,894 Views)
Really building an RT application on an RT desktop?
Kudos are welcome...
Message 3 of 9
(3,885 Views)
And another hint:
Error code 7 is used for several possible errors. One is for missing files, another is a GPIB error code. Hence you get two possible explainations.
Regards, Jens
Message 4 of 9
(3,869 Views)
well, it a normal Laptop with the NI Realtime OS and i use the FPGA from a CRIO9074.
The GPIB Error is in my opinion a known software bug, it occurs everytime when something is missing, such as Data.
But as i said, the VI is definitely in the correct folder.
If i take another VI, e.g. with s simple code (Rolling Counter) the build on a standalone RT application works without any problems.
Message 5 of 9
(3,853 Views)
Hy,
i got a little success.
I was able to build to RT Standalone applikation.
I added the Bitfile from the FPGA applikation to my desktop rt "part" via the NI project explorer.
A new problem occured:
If i deploy the created RT standalone build, my desktop RT shows an error message:
Error loading 'lvfpga_runt.dll': Missung export ' CryptAcquireContextA' from 'ADVAPI32.DLL'
Whats now the problem for my RT 😞 ?
Message 6 of 9
(3,837 Views)
Hi Ben,
You want to say you hadn't the FPGA part in your project before? That's definitely not the way to go…
You really should discuss this problem with NI directly. They know all prerequisites to create a RTEXE.
Your use case is rather uncommon with RT on a standard PC and network access to your FPGA, so I guess not too much people will have the exact same system setup and stumble upon the same problems…
Message 7 of 9
(3,833 Views)
Attached is my project structure:
I mean i got a FPGA that runs on my crio and transfers data via DMA FIFO to my RT Desktop PC.
Because i open a FPGA Refernce via the RT PC i have to add the bitfile to the "RT Desktop" Subfolder.
Message 8 of 9
(3,828 Views)
Hi Ben,
I think we already discussed this topic in the German LabVIEWForum.
Between your RT desktop PC and your cRIO FPGA is not only a DMA FIFO, but also a network connection!
Usually you have the FPGA resources completely (all VIs, build settings, and so on) in your project. I guess the NI compiler tools expect all FPGA resources like that.
Did you discuss this with NI support? What do they say about your problem?
Message 9 of 9
(3,825 Views)
