RT Palette bug?
Hello everyone.
I'm glad I can join the LV community (It's my first post here). But let's get down to business.
Can anyone pelase check if it's a problem only in my case or if it's a general bug.
I tried to find the RT Watchdog's palette but I filed. The search option in the palette's menu didn's work either. I knew it should be there because I found it's description in the
LV help. I tried the "Place on the block diagram" option and it worked (the palette was still missing though). The most interesing thing happened when I used the  "Find on the Functions palette" option. I worked...well sort of. I found the palette but if I tried to resize the window It would disappear and I would see the general Functions palette. I tried to go "Up to owning palette" and that worked but as in previous case if I tried to resize the window the Watchdogs palette's icon would disappear.
Doeas anyone know what can cause the problem here?
I found that It's the same case with the "Real-Time Analysis Utilities".
I'm using LV 8.5 + LV RT 8.5 installed on WinXP Professional
Regards
Nicolas
Message 1 of 1
(2,762 Views)
