RS485
I'm trying to simulate using an RS485 cable, through COM ports...
Is there any way to set the DTR in labview 5 (the easier, the better ->
preferably using the Serial port VI's)?
I know that in turbo C/C++, this would work...
if(format == 1) outp(comport+1,(inp(comport+1)&253));
// assert DTR line for Data direction control - Test Set needs that for
// RS485 port direction control
and to release it,
outp(comport+1,(inp(comport+1)|2)); // Release DTR line - ready to receive
but I can't find anything in Labview, that I can get working
Slade Squire
Programmer
Rectifier Technologies Pacific
Melbourne, Australia
SladeSquire@rtp.com.au
(3,237 Views)
You can set DTR with a VISA-Proberty-Node. Open the example-VI in attachment.
Christian
Test Engineering
digades GmbH
www.digades.com
(3,237 Views)
Use 'serial line ctrl.vi' in \vi.lib\INSTR\_sersup.llb.
It allows you to control DTR and CTS.
"Slade Squire" wrote in message news:9oom5h$38d$1@perki.connect.com.au...
> and to release it,
> Slade Squire
> Programmer
(3,237 Views)
You might try the functions In Port.vi and Out Port.vi under the
Functions-> Advanced -> PortI/O palette. This lets you do something very
similar to the C code inp and outp. If you are running NT, you will need a
different version of these vis than the ones supplied, as well as the
CVIRTE.dll. See the link
http://digital.ni.com/public.nsf/websearch/62790c9621f599cf8625659f0068e6e9?
OpenDocument which talks more about using In Port and Out Port on NT.
Hope this helps.
Jim
Slade Squire wrote in message
> I kn
> and to release it,
receive
> Slade Squire
> Programmer
(3,237 Views)
