RS485 Communication - Parity Error
Did you try RavensFan's 2 ideas?
"First, make sure you have parity error replacement DISABLED.
If you do not care about that 9th bit, then just read 8 bytes (do not use bytes at port), and ignore the parity error that you are guaranteed to get.  Somewhere there is a function called Clear Specific Error.   You could also use the general error handler.  Or unbundle the error code and feed it to a case structure that sends no error if it is a parity error, and passes through all other errors and warnings."
Message 21 of 24
(1,820 Views)
Kodester,
I have double checked the disabled function.
Right now i'm using case structure to bypass my error so that I can write something on the default case.
Message 22 of 24
(1,807 Views)
So everything is working just fine now.  Your question has been solved.
Message 23 of 24
(1,803 Views)
RavensFan,
At this point I hope this is the best solution as you suggested. I'll go head and accept the solution and close it. Later when I find something new I'll addup to the post.
Thank you all!!
Message 24 of 24
(1,794 Views)
