RS232 write with MagPro stimulator
I'm trying to put together a protocol using a National Instruments Labview program to control a MagPro R30 transcranial magnetic stimulator through a 9-pin serial port. I have previously been able to receive trigger signals from the MagPro in Labview, using VISA Read block, so I know that the connection and the basic setup of the VISA is correct, but I'm having more trouble sending signals to it. I have tried using the VISA Write block (with the command string as "*TRIG\n") and the VISA Assert Trigger block (using every available protocol).
Please let me know if you have any suggestions about this. I have also contacted the company responsible for the stimulator for advice.
Thank you.
(2,664 Views)
Are you sure that the command you sent was with the display in \codes mode?
As in \n is the line feed character as opposed to a slash and an "n" as two separate characters.
(2,661 Views)
I believe that "\n" was meant to be the termination character. I'm not sure, though - I just took that string from what the help file said that the Assert Trigger command would use for a serial port.
(2,655 Views)
The manufacturer of the stimulator has indicated that I may have been working with the wrong port, or that the stimulator may be too old to update to the necessary version. So this is probably not a Labview program at all. Thank you for help, regardless.
(2,644 Views)
