RS232 command writing using LV 7.0
I need to write some code using LV 7.0 to interface with RS232 port, pls help to send me some sample code base on below requirements. I am not fimilar with RS232 interface programming. How to write and read back thru RS232 ?
"Send the following RS232 command : 00FE5481<CR>
This will run a test which writes data to each location in the EEPROM and reads it back. After about 10 seconds. An error flag will be set while the test is in progress and cleared when it is complete. A second error flag will be set if there are any errors in the data read.
This can be checked by sending a Request Status : 00EE01<CR>.
(2,445 Views)
Duplicate thread.  Please see replies to this post at this location
(2,431 Views)
