RS232 Communication
I am participating in a senior design project which requires me to use LabVIEW.  I am new to this software; however I am supposed to generate code using this program to implement the communication between an RF Modem (Ewave Super Screamer) and LabVIEW to establish that it works.  How would I go about implementing this and what information do I need to know in order to start testing.  The modem is compatible with serial RS232, but that's all I know...need help ASAP.
M. Tweh
(2,873 Views)
Well, start by reading the getting started manual.  Since you are trying to get information IN from and send information OUT to and INSTRUMENT, I would then use the Instrument I/O Assistant Express VI.  I believe that it is covered in the manual.  That should do it.
Hope that this helps,
Bob Young
(2,865 Views)
Hi Labviewbeginner,
it's always a very good start with "Find Examples" in the Help-menu. In my LV 7.1 I find the appropriate examples in "Harware In- & Output"->"Serial". A very good start would be "Basic Serial Write and Read", there you can send some String to the modem and after a customizable delay read the answer. If You right-click on the String- control & indicator, you can select "Hex- Display" to input or read your string in hexadecimal notation.
Hope, this helps,
Dave
Greets, Dave
(2,864 Views)
