RS 232 to mA conversion
I am planning to use Labview for data acquisition and I have a few 4-20 mA signals coming in, that I want to monitor. I also have an instrument which gives O/P through an RS 232 cable. Is there a way I can convert the signal to 4-20 mA so that I can direct it to Labview via I-Net 100 ?
(2,733 Views)
Why do all of that?
Just use LabVIEW to read the serial port.  There are examples such as Basic Serial Write and Read in the example finder.
(2,728 Views)
Thank you  for the reply Ravens Fan.
I am using Labview for the first time. I apologize for any silly questions.
So, can I use Labview to directly read the serial port? Do I need any interfacing hardware?
(2,721 Views)
Accepted by topic author Seema
Nope.
Just a serial port.  Many new PC's lack the old fashioned DB9 serial ports.  So if you don't have one, you'll need a USB to RS-232 converter.  Its drivers create a virtual com port.  It will show up as Com6 or 7 or some unused number in your system.
I'm not familiar with the I-Net 100 that will read your 4-20mA signals.  Hopefully they will provide whatever drivers you might need so that LabVIEW can read that DAQ device.
(2,708 Views)
Thank you very much Ravens Fan
(2,702 Views)
