RS-232 problems
I Am sending commands to a instrument wich then sending me a continously stream
of data. There should be at lest 20Kbytes.
I only receive 1024bytes. I use the "serial port read.vi" and ask for 5000
bytes. The speed are 9600 baud and the settings at the PC and instrument
are correct. The receive/transmitt -buffer in the control panel are both
high. When I use hyperterminal I get all the data. What could be the problem?
In advance! Thanks for a tips.
(2,971 Views)
On 11 May 2000 08:30:19 -0500, "Tor Ivan Karlsen"
Do you use the get number of bytes vi? and one thing I found out was
to put a delay in the receive section otherwise this can make your
machine run so slow its like its shut down.
I wait for 500 bytes then read the buffer process i
t and come back
and get another 500 bytes and my serial port is running at 19.2k
Hope I helped in some way.
Steve Drake
(2,971 Views)
