RS-232 on sb RIO 9636
Hello!
I am using Sabertooth driver 2x25 and Single BoardRIO 9636. I am trying to send data to Sabertooth over RS-232 (need only Serial Write) and my question is should I use NI VISA driver for that? Also, what is the range of output voltage of RS-232 (because Sabertooth works at TTL level)? Could you please attach some simple example if you have?
Thanks in advance,
Chupka
(3,499 Views)
Yes, you should use VISA for this, also the voltage level will be too high. You will need to use something like a max233 chip to drop the voltage down to TTL for your device.
(3,491 Views)
Sorry I misread original post and thought you had a comapct RIO. I think the SB RIO uses 3.3V logic, but I am sure someone at NI can clarify.
(3,484 Views)
Same applies - the sbRIO 9636 has RS-232 ports so it will be RS-232 voltage levels. You'll need to use a line transceiver to convert it down to TTL levels for a microcontroller. In that case, you'd use NI VISA.
You *can* also implement the serial communications using the digital I/O lines and some FPGA code.
(blog)
(3,459 Views)
Sam,
thank You for Your reply. I have two more questions.
Do I have VISA driver - how should I know that? (I have installed LV, LV RT and LV FPGA from the installation CDs that come with sbRIO 9636 Evaluation Kit)
When I make VI that contains VISA functions where I should make it - under RT, under Target, or...?
Thanks in advance,
Chupka
(3,439 Views)
Look in NI MAX - NI VISA is part of the device drivers list so you should see it listed under 'Software' in MAX.
The RS-232 port is on the RT controller, so the VI that uses the RS-232 port needs to be under the RT Chassis in the project.
(blog)
(3,414 Views)
