RS-232 Error
All,
I am working on developing a labview application on a remote computer.  I then build the application as an EXE and distribute it to another computer.  I have run into a problem, when I try to run the program.  I have a drop down box that I can select the communication VISA serial source.  When I refresh this drop down menu, it only returns the Ethernet device.  My COM1 and COM2 ports are not an option for this menu.  I have tested the port through hyper terminal, but I am unable to select it from the labview files I compiled in Labview 8.0.
Any suggestions?
Joe
(3,942 Views)
Does this drop-down VISA resource work on a VI?  As opposed to your built executable?
-Khalid
(3,928 Views)
I do not know, as I have no way to test that.  Since I can only install the runtime engine, I cannot run a regular VI on this machine.  Do you know of any other ways that I can do that on this machine that does not have a full version of labview installed?
Joe
(3,927 Views)
Did you also include the VISA run-time with the installation?
(3,922 Views)
I do not know.  I will see what I can do and repost soon.
Thank you
(3,920 Views)
Hi Joseph,
In order to see the serial ports in the VISA resource name meny, you will need to install either NI-VISA, or the NI-VISA runtime engine on your target computer.  You can find downloads for both here.
Ebele O.
(3,895 Views)
Thanks guys!
That seemed to help.
Joe
(3,886 Views)
