RS 232 Basic Challenge
A second challenge I am having is this:
A governor exists which sends streams of ASCII data to a printer on demand (RS232), by pressing a button on the governor. I would like to disconnect the printer and instead capture that stream of data with labVIEW and send it to a file.
I havent done a project of this scale before and would like to enquire what I would need for this task. Do I need an RS 232 cable connecting the governor to a device on the PC that would run the LabVIEW code?
I need an advice please.
Thanks.
Message 1 of 8
(3,691 Views)
The first thing you need is to understand the communication protocoll of the printer. Do you have any documentation for your printer where it is explaned?
Message 2 of 8
(3,689 Views)
I would look to see if the manuals exist and get back, hopefully on Monday. Is there any information I need to gather from the governor as well? Thanks a lot Eugen.
Message 3 of 8
(3,679 Views)
Sorry, I don't understand what you mean with governor...
You need in principle to simulate your printer through LabVIEW . Your programm should aswer to commands like printer and sample data from the other side.
Or you can don't break the communication and only spy them. You can make a RS232 cable which will spy all the data send to printer.If so, than it's easier, because you'll dont't need to answer  to commands.
Message 4 of 8
(3,677 Views)
Thank a lot Eugen. Actually, the governor (governing system) monitors a number of machines and picks up useful parameters from them. It sends these useful parameters to the printer, for printing when it is primpted to do so by a button on the governing system. The printing system has not been good, which has made it necessary to use a file to log the data stored in the governing system.
The task now is when prompted the data should not go to the printer, rather it should be routed to a file on a PC. That is what promted my question in the first place. How I can use labVIEW to pick the parameters (in ASCII stream form) from the governing system and route it to a file instead of a printer.
Thanks.
Message 5 of 8
(3,671 Views)
Ok, I understand you now. As I said you will need to know about communication protocol. Just google a little or try to find the documentation for your printer.
http://www.google.de/search?hl=ru&ei=KyxrSsiBJYuI_AaL9tF9&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=st...
Message 6 of 8
(3,664 Views)
Thanks a lot. I would try to get information on data sheets for both the printer and the governing system and hopefully get some feedback across on Monday.
Thanks once again.
Message 7 of 8
(3,657 Views)
Which monday you are talking about?Smiley Wink
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 8 of 8
(3,610 Views)
