RPC Server not listening error
When I try to open an MS Access 2002 form with activeX, I get an error -2147023181 (RPC server is not listening). Both my LV application and MS Access database are compiled. With non-compiled versions everything works fine. Is there a workaround?
thanks for help
(4,552 Views)
Are you using any NI hardware? This error is not in our error database, and it could be related to Microsoft RPC. If you do not use any hardware from National Instruments, then you should contact Microsoft about this error.
Zvezdana S.
(4,552 Views)
thanks for your answer. MS told me that the problem is in MS Access distribution kit, since the CreateObject call is not supported in the run-time environment. So... no workarounds but purchasing Access full licences...
Giovanni
(4,552 Views)
