RING MENU
Hi!
I have a problem with one program. I need to add and delete elements of the menu ring when the program is running. Can i do it? Somebody please help me
(3,397 Views)
You need to use the Strings[] property to change the list of items. Note that we are assuming you're using a menu ring, and not an enum.
(3,392 Views)
Thanks... Its not what im looking for but it works
(3,378 Views)
What do you mean it's not what you were looking for? What were you looking for? That's how you set the menu ring's string items.
(3,347 Views)
Yes but I want to add elemnts when I press a button when my program is running and delete with another button too
(3,341 Views)
Just place the property in an event for each button.
(3,329 Views)
I just showed you how to set the items. If you want to change it via buttons then you need to read/write that property node by modifying the array. There is no "add" or "delete" method for the list of items. You have to read the current list, modify it, and then write it back. One simple way is as Dennis suggested and to use an event structure and in each event handler you read the current array, add or delete an element, and then write the new array to the property. Ultimately, though, that property is how you set the elements.
(3,308 Views)
