RIGOL DSA815 Channel Power measurement
I've set up a NI USRP-2920 to put out a continuous signal at 406.04MHz with IQ Sampling at 200k s/sec, Gain 1db, and tone Freq at 10k. using the RIGOL 815 I can see the signal clearly. I am trying to measure the Channel Power.
Is there something I'm missing in the setup/configuration?
Keith
P.S. Running LabView Professional 2017 32-bit, on Windows 10 Pro
(1,496 Views)
Hi Keith,
What's the issue? Are you not getting a value in the "Chan Power" indicator? Are you getting only 0 or NaN?
Or do you just want to double-check that the setup is correct? (i.e. that the VIs you used before the while loop are appropriate for what you are trying to achieve)
(1,467 Views)
