RGB transform
Hi all ,
I want to extact the 3 components R,G,B of an image and convert them in a
space of two dimension trough two formulas like as :
a=f(R,G,B)
b=g(R,G,B)
Where f and g are two simple rational functions .
I have used IMAQ ColorImageToArray connected with IMAQ IntegerToColorValue ,
is it correct ?
How do I realize this transformations ?
(I think I have to use a for loop to scan image pixels ...)
(3,427 Views)
Perdus,
You have to use two for loops (nested), one for each dimension.
I don't have IMAQ installed, so the attached example reads jpg. It should be
easy to convert. Make sure the opened jpg is 24 bit. If you want a picture
for both a and b, you can put a and b in to different 2d arrays.
Wiebe.
"Pedrus" wrote in message
news:WEJmc.157084$hc5.6721270@news3.tin.it...
> Hi all ,
> a=f(R,G,B)
> b=g(R,G,B)
> is it correct ?
mations ?
[Attachment exp 4.vi, see below]
(3,427 Views)
Bonjour,
comment émuler la fonction RTSI (synchronisation de l'acquisition entre les
cartes PCI 4472 et 4474) avec DAQmx version 7.2 ?
A l'éxécution de l'exemple Multi-Device Synch-Shared Timebase-Cont
Acquisition.vi, j'obtiens le message d'erreur suivant :
L'erreur -200452 s'est produite à Noeud de propriété DAQmx Timing (arg 1)
dans Multi-Device Synch-Shared Timebase-Cont Acquisition.vi
Raison(s) possible(s) :
Specified property is not supported by the device or is not applicable to
the task.
Property: MasterTimebase.Src
Task Name: _unnamedTask<3>
(3,427 Views)
My ask is very different from your answer !!!!
"Amandine" ha scritto nel messaggio
news:c7g6l8$723$1@news-reader4.wanadoo.fr...
> Bonjour,
les
> the task.
(3,427 Views)
