RFSA and RFSG driver 64 bits support
Is it panned by NI to support RFSA and RFSG driver in 64 bits platform like Windows 7 64bits. If yes, what is the expected date to release this driver. Is there a Beta version available.
Thank you
Dany Allard
LabVIEW ChampionArchitect
(3,584 Views)
Please look at the following link
Cory K
(3,579 Views)
The current version of the driver are 32bits. What I can see is I can install those 32bits driver on a 64bits OS.
But If I want to use LabVIEW 64bits or a 64 bits compiler it will fail?
Quote from this web page
Minimum Application Development Environments:
You can use NI-RFSG in the LabVIEW and LabWindows/CVI application development environments (ADEs). The minimum versions of these ADEs that can be used with NI-RFSG are listed below.
Supported Application Development Environments:
  • NI LabVIEW 8.2.1, 8.5.1, 8.6.1, or NI LabVIEW 2009 (32-bit) Full Development System or Professional Development System
  • NI LabVIEW Real-Time Module 8.5.1 or later
  • LabWindowsTM/CVITM 7.1.1 or later
  • LabWindowsTM/CVITM Real-Time Module 9.0 or later
  • Any C compiler capable of calling a 32-bit DLL
(3,567 Views)
