RFID,GSM MODULE, ARDUINO
I have a project regarding to a train station here and I'm trying to create a VI that will cater to this specifications:
a.) The user will send a SMS to the system regarding on what station he/she is.
b.) The system will check the nearest train the the sender (Using RFID) and send a SMS to the user (Using GSM module) the ETA of the Train and whether the train is FULL,SKIP or can be ride onto.
My question is this:
a.)Where to start?
b.)What Labview modules i can use to interface with RFID and GSM.
c.) Does VISA work here?
Thanks! 🙂
(4,433 Views)
You goona need requirement and interfacing details. Instead of GSM you need AT commands
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,431 Views)
Instead of Using GSM Module i just need AT commands? So i will not buy GSM module(hardware). Thanks for your Reply! 🙂
(4,383 Views)
Ignore the previous response. To send and SMS, you would need a GSM modem and the software would be AT commands sent/read with VISA.
(4,378 Views)
I'm done with my sms 🙂 thanks! my new problem is that, how can i connect my rfid to arduino to labview. any manuals,instruction, link  to that ?
(4,347 Views)
You need to buy GSM module for sending AT commands. It will not do any magic for sending SMS
--Ranjeet
(4,345 Views)
You gonna need this
1. RFID --> Arduino --> Labview
2.  RFID --> Labview
     Arduino - Labview.
Anyhow you need to communicate to arduino using LV. Hence you can either go for interfacing RFID and Arduino to LV or RFID to arduino and arduino to LV
--Ranjeet
(4,344 Views)
