RESIZE TABLE
I want to show a 34*44 table in front panel.
I am having other controls and indicators as well.
So I want to resize my table to fit in a particular position of my front panel.
When I am trying to resize my table, the vertical/horizontal scroll bars are getting activated.
But I want the entite table to fit and thus by resizing all of its cells.
How can I possibly do that?
(3,780 Views)
If you drag the edges of a Table indicator, it grows to include more rows or controls, so I'm not sure what your issue is...
You can drag the individual row or column edges to change the sizes of the cells as well.
Maybe you can try using an array indicator instead? If the above doesn't work, include a screenshot of the table you're having issues with.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,759 Views)
As you can see in the attached screen, only a limited portion of the grid can be seen. I want to fit all cells and thereby eliminate the need to use the scroll bars.
(3,733 Views)
Hi ni4me,
why don't you set the cell sizes (aka column width and row heights)? There are properties available to do so!
(3,707 Views)
