REAL buttons and dials on Pocket PC
Hi All,
I am working on a Pocket PC project.  Instead of using a touch screen, I am trying to use REAL buttons, clickers, dials, or tracking ball as the user interface.   Has any one worked on encoders or anything that will help on that before?
(2,850 Views)
Hi hellolv, do you want to use the hardware buttons of your PDA or you want to add additional hardware to the PDA?
For working with the buttons on the PDA there is an example in LabVIEW search examples.
In case you want to use additional hardware depending on your PDA if it has USB you can connect a USB DAQ card and receive your inputs through there.
Best Regards
Benjamin C
Principal Systems Engineer // CLA // CLED
(2,812 Views)
