R6025 Error in runtime
First of all thanks a lot for reading this post and being able to help.
I am running an aplication .exe with Imaqdx.
Sometime it occurs this exception R6025 pure virtual function call.
I would like if I have to reinstall vision develpment module run time or what I have to do because it starts to occur now meanwhile it has been working well for months.
Thanks a lot.
(2,695 Views)
I found some useful information from Microsoft that explains the reason behind this error, please see the following link:
C Runtime Error R6025
Also, you can try suggestions from this link:
Runtime error P6025 pure virtual function call on Program C:\Windows\Explorer.exe Windows 7
It's also possible to get this issue when a PCI card is no longer recognised by your system.
I'll leave the following forum cases links. Hope you'll find the reason for the issue you have. Please share with the community about the results.
Runtime error R6025 in a built app using static ref and Fieldpoint
What is R6025 Pure virtual function call run-time error?
(2,527 Views)
Thanks a lot for your reply Sr.
I solved the problem by rearranging my code.
So I think I had some issues in my code...
Thanks a lot Sr. I will check your links.
(2,523 Views)
