10-12-2021 08:34 AM
Hi all, I'm new with lab view and I'm using a R&S HMC 8042 ROHDE & SCHWARZ, Power supply. I have installed its driver and now I try to read from a file and give the result to the power supply. Could you please help me with which functions I need and how I need to connect them? Do I need to install GPIB?
It seems USB IS working because it is shown in the lab view, but I can not read or write data. I'm attaching the screenshot.
Thank you so much in advance.
10-12-2021 10:07 AM
you wrote you downloaded the driver, but you are not using it. First, read the R&S Driver app note 1MA228:
Use the LabVIEW palette Diagram -> Instr Drivers to access the driver's VIs. Which files you want to transfer to the instrument?
BR
Milo
10-12-2021 11:12 AM
Hi, thank you so much for your response.
I'm using it but the communication is not working (I tried USB and serial both)
It is just a simple file that I need to send from my pc to the power supply by USB every 1 min. It is a text file with some current values.
At this point, I really need some examples. That would be really appreciated if you can help me.
10-13-2021 02:34 AM
I think you need help with establishing a connection, VCP or USB-TMC, and then fulfill your measurement task. I suggest to contact our customer support, they will be able to help you:
https://gloris.rohde-schwarz.com/anonymous/en/pages/toplevel/service_support_requests.html
Milo
