Quit LabVIEW
I have 3 exes, all built from LabVIEW VI's.
2 of them run for a long duration, but for one of the exes, when it is called, it just needs to run once, then it can close.
I am calling it from the command prompt, through a batch file:
eg. start path/program.exe
If I put a 'Quit LabVIEW' function at the end of the code, will it just close this exe, or all of them?
Or is there a better way to accomplish this task?
Cory K
Message 1 of 8
(5,095 Views)
Darren has published a nugget on shuting down the app using FP.Close.
Felix
Message 2 of 8
(5,090 Views)
From my experinece the Quit LabVIEW will only affect the application that contains it. So if you have a built application it will only exit that one application. If you use it in the development environment LabVIEW itself will shutdown.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(5,087 Views)
Accepted by topic author Cory_K
It'll just quit the one.
I use this at the end of code quite a lot, and I pragmatically determine to use Quit or not depending if it is an EXE or Dev mode.
Richard
Message 4 of 8
(5,084 Views)
Smiley Very Happy The spell check changed "programmatically" to "pragmatically"! Smiley Very Happy I guess they are both correct.
Richard
Message 5 of 8
(5,055 Views)
Quit App instance is NOT the same as Quit LabVIEW.  Honestly, I do not know the (specifics of) difference--- Smerc, Darren, or Ben might though.  Need a LV Champ to follow through on the sepcs.
"Should be" isn't "Is" -Jay
Message 6 of 8
(5,048 Views)
I just made a few small test exe's just to check.
As stated above:
- if they are all exe's, 'quit LabVIEW' will only exit the exe in which that function was called
- if they are all open VI's, 'quit LabVIEW' will close the whole environment, closing all open VI's
So in my case, I can get away with using quit LabVIEW.
Cory K
Message 7 of 8
(5,023 Views)
Cory:
Sorry I'm late to the party, your tests are indeed correct. I have a PC on the floor that has two LabVIEW exe's on it. When they quit one application the other one still keeps running.
-AK2DM
Message 8 of 8
(5,011 Views)
