Quickly Get Heat Map as Image (Code Review Request)
My VI is receiving about 5k - 10k rows from a database table with the following information:
X(mm)     Y(mm)    occurrence(#)
0000.00  0000.00      002
0002.00  0000.00      052
0005.00  0000.00      071
9999.00  0578.00      300
I would like to take the data and quickly generate an image that I can overlay drawing elements (circles) that will highlight areas of interest.
Is there any way I can improve this vi to
  • Stop using the hidden 3dplot control
  • Add an X,Y axis
  • Render the image more quickly
Message 1 of 8
(5,433 Views)
Instead of drawing by points couldn't you just convert your data to a pixel array and use Draw Unflattened Pixmap? I think by default your points will be pixels but you could fuzz each one to include neighbor pixels as well, right?
(I don't use much picture stuff, sorry).
Message 2 of 8
(5,424 Views)
Just use an intensity graph and quantize the x and y values to a reasonable grid. You can easily do a 2D histogram as described here.
Initialize a 2D I32 array, place in shift register, autoindex on data and use the IPE to increment values at scaled X,Y to array indices. Use a nice color ramp for the z scale.
Message 3 of 8
(5,423 Views)
@altenbach wrote:
Just use an intensity graph and quantize the x and y values to a reasonable grid. You can easily do a 2D histogram ...
Here's what I had in mind...
(you can hide the x and y scales or remap them to actual values using x0/dx if the scaling is different)
Message 4 of 8
(5,412 Views)
I like the intensity graph, but how would I draw the user's regions of interest on the graph? (eg, a circle r 30 at XY=0,0)
Message 5 of 8
(5,397 Views)
Hi JScherer,
you can draw those circles into a 2DPicture and use that picture as front image (by property node) of the intensity graph…
Message 6 of 8
(5,390 Views)
"Plot images" property.
(example to draw a line, but any 2D image tools are of course allowed)
Here's an old example drawing circles on an intensity graph.
Message 7 of 8
(5,371 Views)
Accepted by topic author JScherer
Simplified example:
(To do: Size graph area such that pixels are square, ensure execution order (draw circles only after axes have autoscaled), Do axis mapping such that data and axes can go from -100 ..+100, etc.)
Message 8 of 8
(5,357 Views)
