Queued message handler, handling events based on message loop outputs.
I have a queued message handler with an event handler (producer) and a message handler (consumer). I want a certain series of events in the event loop to occur when the message handler completes its queue. I created a new queue with the completed output message, but when I access the dequeued message in my event loop using property nodes to access their values, the main event loop waits until this message arrives. I am new to labview and am sure I have done something incorrect. Any help would be appreciated. The message handling loop will eventually reside in a real time SB Rio and I am trying to simulate the interaction between the host and the real time machines.
(2,360 Views)
couldn't open your code in LV17, Could you save it in earlier version and upload it.
(2,352 Views)
What I do to send messages back to the GUI (event) loop is use User Events.  These work with the Event Structure.
Well, you are going to want a loop on the PC side that does nothing but try to talk with the sbRIO and then use the User Event that I mentioned before to get the updated data to the event loop.  You will likely want to do something similar on the sbRIO side, but use a queue to get the data to the message handler.
(2,322 Views)
