Queue overflowing issue
I have a control system that uses image RT acquisition using queue structure.
Up until now, I have created reference signal from LabView directly, and now I am trying to read in the reference signal from the csv file before running the control loop.
However, I am encountering the error where it says that I am encountering overflow in my queue.
My question is how come this error shows up even thought the data size of the generated signal and imported signal is same.
Thanks.
(2,876 Views)
How did you set up your queue, what is the maximum size? And how/how often are you reading (emptying) your queue?
Corey Rotunno
(2,857 Views)
