Questions on Xontrol--How to update the state and data
Hello, everyone. I am new to use the XControl. I don't understand how the program in the facade update the "state" and "Data" after we click the button. I cannot do that, please give me some help on the XControl.
My vi is in the attachment.
Message Edited by McArthur on 03-24-2010 02:19 AM
Working...
(3,862 Views)
Several things don't make a lot of sense. I would recommend you study the shipping example (look for dual mode thermometer in the example finder).
  • You seem to not even use the "data", but increment the "state". Wouldn't it be more reasonable to use the data?
  • There is a primitive for "+1", no need for the "1" diagram constant.
  • You seem to work with integers, so use an integer (blue) numeric instead of floating point (orange) representation for the data.
  • When you modify data or state, you need to update the action cluster to indicate that fact.
  • Your boolean button terminals should be inside their respective events so they properly get read and reset.
  • I would use "value changed" instead of "mouse up" events.
Can you explain in a few words what the xcontrol is supposed to do. What is the functionality?
Looking at the code gives no real obvious hints to me. 😉
(3,851 Views)
You should set the Action.State Changed? boolean:
Ton
Message Edited by TCPlomp on 24-03-2010 08:51 AM
My LabVIEW Ideas
(3,844 Views)
Thank you both of you!
The example is just a dummy, not really make sense.
Now I understand the reason why the state can not update, because I didn't do as TCPlomp mentioned. It seems working now....Smiley Happy
Working...
(3,833 Views)
 I mentioned this too, however without a pretty picture. 😉
The example is really quite good and shows these things too as well as many other important points. Please try to fully understand it.
I would strongly advise you to also look at my other suggestions. You still haven't explained the purpose of the xcontrol. I am still curious. 😉
(3,810 Views)
Thank you both of you, ! I mentioned about you.Smiley Happy
Yes, the other points are very good. Thank you very much....
Message Edited by McArthur on 03-25-2010 07:29 AM
Working...
(3,799 Views)
