Question regarding serial communication development
hope you should help me.
I have to communicate with a matrix audio video switcher, able to
be managed via RS 232.
I tried to create many vis to perform it but unfortunately it did not
work 😞
First, I used VISA Write command to send 4 bytes to the instrument, it
works fine, but while data sent were a string, my switcher received
ascii and didn't recognize my command.
Second, I used Out port command, nothing was sent to my serial bus.
I found many other integrated visa function, but I was not able to use
them properly...
Should anyone be able to help me?
Thanks in advance.
Olivier
(2,780 Views)
Oliver,
some hints:
a) You should use the VISA vis not the Outport!
b) A string is just an array of bytes
1.Open the 'Serial Communication.vi' Example (Help-Find Example)
2.Save it as your own copy with a different name,location (with aktiv checkbox 'save a copy without updating callers'), close example,open your copy
3. If needed add controlls to your vi for the correct initialisation of the serial port. if you get responses as raw binary values, make shure all termination characters are turned off.
4. right click the write-string control (and read string indicator) and choose the display style you need (for raw data maybe hex? I prefer '\-code' read online doc for more help)
5. give it a try
Greetings from Germany
Henrik
Henrik
LV since v3.1
(2,780 Views)
Olivier wrote:
> Hello,
> work 😞
The serial-comms VISA vi's can only send data. But A String is basically
an array of bytes. So if you want to send binary date (numbers) just
fill an Array of U8, convert it to a string with the function Array of
U8 to Strin and it should be done.
Hope this helps
Marco Tedaldi
(2,780 Views)
Hi all,
I'd like to thank you very much for your answers, indications you gave
me permitted a good use of data send 😉
Kind regards,
Olivier
(2,780 Views)
