Question on Project Files Migration
What should be the best practice for project folder migration from computer to computer so LV always finds all VIs including Drivers in the same folder.
Regards
FLiu
(3,133 Views)
Are you keeping everything in source code control? If not, start doing that immediately. As long as the server used to store the files in your various folders is available to all computers, keeping up with changes is pretty basic.
(3,120 Views)
In addition to what Dennis mentionned, you can use the project manager to zip the entire set of files needed for the project.  The feature is found at the bottom of the project hierarchy where you normally build executables.  Sorry for the lack of precise information, I do not have LabVIEW installed on this machine.
If you use source control and are more than one developer on multiple machines, you may need to be careful because some source control applications do not deal well with non-text sources.
(3,115 Views)
