Question about the data acquisition.
I am quite confused about the sampling speed and relevant clock of my NI instrument. I used the NI-5781  adapter module in my data acquisition, which is also labelled as  100MS/s Baseband Transceiver. I originally thought that the sampling rate should be able to reach at least tens of mega samples per second, but it turned out that the actual speed of acquisition displayed on the computer screen is only 100 KS/s. May I ask why it is much slower than the 100 MS/s speed?
In terms of the clock, I searched the manual for the NI-5781 and find that the internal clock is called VCXO at 100 MHz. I think it is the clock determining the sampling rate, right? But why the data sampling on the computer is much slower? Is that because of the FPGA processing rate or the computer or anything else? (The FPGA I used with the adapter module is PXIe-7966R). By the way, when I program on the LabVIEW FPGA, I used the '40 MHz' on-board clock, could you please tell me that is this clock on the computer hardware or on the FPGA, and what relation it has with the sampling rate?  I would really appreciate it if you can help me. I am really struggling with them can not figure them out for several weeks...
The picture attached is the program I currently have with a sampling rate of 100 KS/s. It already contains 2 loops, but the sampling speed is not as fast as it should be. If it is because I am not reading out of the DMA channel on the Host side (Windows PC) fast enough, what should I do? Should I just add another loop with only the function 'IO Module/AI 0' in it, put the other mathematic operation and visualization in a second loop, and put the functions that writing acquired data to the TDMS file to a third loop?
Another problem I met is the noise in the signal (as shown in the second figure). When I was trying to acquire data from a constant voltage signal (I have measured it using an oscilloscope and it is a fixed value around 1.5 V), I get plenty of glitches in my waveform as shown in the attached figure. Is that because my data acquisition device has some problem or because my program is not that good?
Finally, I am tried to record my data into a TDMS file. I opened the TDMS file in the format of Excel. But it seems that I can only see a maximum of 1048575 data in an excel file. Is there any solution to save more data, or should I create multiple TDMS files to save them?   (Sorry for so many questions as I am quite new to the area of DAQ and LabVIEW😭)
Message 1 of 10
(3,679 Views)
1. You should be using a DMA FIFO to pass your data from the FPGA to the host.  Otherwise, you are just getting the values when the host just happens to decide to look at the variable.  This is your main timing issue.
2. Excel is limited in how many lines it can show.  If you want to see more from a TDMS file, then you will want to look at either DIAdem from NI or Scout from Signal.X.
I would have to do some major digging to figure out how to really interface with your FlexRIO.  Not an architecture I would recommend for a newbie.
Message 2 of 10
(3,650 Views)
Open, run, and review all of the examples listed here: https://zone.ni.com/reference/en-XX/help/372614J-01/friotransamr/5781_transceiver_clipref/
ALE Consultants
Message 3 of 10
(3,632 Views)
Here are some thoughts and suggestions on your issue:
  • The 100MHz clock is the sample clock for the ADCs in the adapter module.  The I/O is being measured at that speed, and then the FPGA passes the data to a DMA FIFO to stream it to RAM on the computer.
    • If you don’t read it out of memory fast enough, the buffer will fill up, and samples will start being over written.
  • The 40MHz is the main rate that the LabVIEW FPGA block diagram is compiled at, but, certain sections of code can run faster than that, using the Single-Cycle Timed Loop structure.  (The 40MHz clock is in the FPGA hardware, not the computer)
  • My guess is that you aren’t reading out of the DMA channel on the Host side (Windows PC) fast enough.  One way around that is to add another loop, just to read data from the DMA channel, and then pass the data to a separate loop to do any math or visualization.
    • It's important to note that you mentioned DMA channels in your post, but the screenshot shows a Read/Write node.  That's likely causing the noise and lost samples in your signal.
    • You can have parallel loops and use FIFOs/Queues in Windows to pass data between your acquisition loop, your loop for processing and visualizing data, and writing data to disk.
  • You could add timers and shift registers to the parallel loops, to benchmark loop speeds, and track down the functions that are taking the longest to execute.
  • You can also allocate more memory and read a larger number of samples at a time, to read in larger blocks and reduce bottlenecks.
Vineet
Message 4 of 10
(3,575 Views)
Hello crossrulz,
Thanks for your suggestion! I have tried to use the DMA FIFO to pass the data, and my new block diagram is shown below. The size of the FPGA DMA FIFO is 1024 and in the host end I set the FIFO depth as 4096 and want to read 1000 data at a time.
What I want to do is like what Vineet said below, to put the DMA channel in a single loop, the math calculation in another loop, and pass the data to the TDMS file in a third loop. However, as the data output from the DMA channel is in the form of 1D array and it seems like I can not directly use the array to do the mathematical calculation in loop 3, I want to extract the elements in the array to do the math calculation and present them on the waveform. I use the 'index array' function, but I think it may only give me the first element of the array, right? But if it is not feasible, what should I do, or which function should I use without changing the function in loop 3?
Another problem I met is the loop and sampling time. I use the loop one to measure the sampling time by measuring the number of iterations of loop 2 per second, multiplied by 1000 (as I set the number of element as 1000 in the DMA channel). What I get is about 400k to 500k samples/s if I do not write data to the TDMS file in loop 4. If I enable the boolean button and write data to the TDMS file, the sampling rate increases to 1M Sample/s. Why is there such a difference?
When I observe the TDMS file, I found the speed is much slower than the sampling rate I measured. For example, I run the program and write to the TDMS file for 10 seconds, I only get less than 1000000 data, which means the data speed into the file is less than 100 K/s and it is much slower than the sampling rate. Is there anything that I did wrong in my program?
Message 5 of 10
(3,537 Views)
And this is my VIs if necessary.
Message 6 of 10
(3,492 Views)
Accepted by topic author XunZou
I think you're getting closer, but here are a few things to watch out for:
  • You're correct that using Index Array is only providing 1 element at a time.  Try putting the full 1000 element 1D array into a Queue, to pass it to your second loop, instead of using a single local variable.
    • You can monitor elements remaining as a way to see if you're able to keep up, or if things are backing up.
    • Depending on your CPU and RAM, you could play with the number of elements in the FIFO depth and the number of elements you're reading, but to achieve 100kS/s continuously, you need to read 1000 samples, 100 times a second, which is probably fine for your top loop.
  • Once you pass the entire array into the Queue, you can read it out, and use a For Loop with auto-indexing to do the mathematical calculations on each element.
  • Lastly, the parallel loop on the top is running independently, and not really measuring the loop times for the other loops.
    • You can use time stamps and shift registers within each loop, and subtract the values between each loop iteration to get the loop speed.  (The Tick Count function should work well for this).
Vineet
Message 7 of 10
(3,476 Views)
Hello Vineet,
Thanks so much! I have tried your method and most problems are solved. However, I am still a little confused about the concept of DMA FIFO. Is it a physical component on the FPGA and host machine, or just an abstract concept that does not actually exist?
Xun Zou
Message 8 of 10
(3,457 Views)
See https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/how-dma-transfers-work-fpga-module.htm...
DMA-FIFOs have buffer elements that exist on the Host and FPGA.
ALE Consultants
Message 9 of 10
(3,455 Views)
Now I get it, thanks!
Message 10 of 10
(3,452 Views)
