Question about the DAQ pulse (TTL) output
Hi Everyone,
My situation is like this: I want to trigger a new pulse (or TTL) signal based on a boolean signal change. The boolean signal comes from the trigger detection from an Analog input signal from sensor, and the length of trigger detection boolean change is pretty short I think.
After the trigger been detected, I want to generate a new pulse signal (signal length can be adjustable) to trigger another device. What is the best way to generate a TTL signal? By using the Analog or digital output?
And since I created a file in the attachment, and seems like it doesn't works for analog output. Is there a better way to do this?
The NI board is NI USB 6221.
(3,749 Views)
@kelisuccess wrote:
Hi Everyone,
Neither, the USB 6221 has a counter.  Use it instead.
"Should be" isn't "Is" -Jay
(3,690 Views)
