Question about tab control
how do you change the text for a page?
I don't see it under property node for the tab control...
(2,535 Views)
When the VI is in edit mode, just double click on a page title.
(2,529 Views)
You can't change the tab label of a tab control page while the VI is running, because the names of the tabs are part of the tab control data type.
You can, however, change page captions programmatically while the VI is running. First, right-click the tab control and deselect Advanced > Make Page Caption Match Label. Then, you can programmatically change the page captions with the Tab Caption property of the 'Page' class:
(2,522 Views)
