Question about Write to Spreadsheet
Does anyone has any idea about how to fixed that ?
(3,706 Views)
Does the c:\data directory exist?
If it doesn't exist, then you'll get this error when LabVIEW tries to create a file inside of it.
(3,701 Views)
It does exist, but the error still shown
(3,696 Views)
Do you have rights to write to a file in that directory?
(3,694 Views)
I think I have,
Here is the file
(3,689 Views)
Your VI works just fine for me when I create a c:\data folder.
What if you pick a different file name?
What if you pick a different directory?
You think you have rights to that directory, but you don't know for sure?  What if you go to that directory from an explorer windows and try to create a new file in it manually.
(3,686 Views)
Is this running on the new NI cRIO-9068?
If so remember that it runs on a Linux kernel! Some information about file paths can be found here: https://www.ni.com/en/shop/linux/under-the-hood-of-ni-linux-real-time.html#section--1175185799
Also, you should ensure that that CSV file exists on the remote system as your host file system has no bearing on where it saves data.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(3,676 Views)
