Question about Run-Time-Menu
Hello everybody,
I have one VI Page_Principale.vi which uses a menu (Finely Run Time). I do not know why when I run this vi and I choose for example the menu «Para_Machine.vi», The Para_Machine.vi display .My problem is when I close this VI by the red cross X , I do not manage any more to choose other menus in Page_Pricpiale.vi.What I have to make in this case for avoid this kind of problem? What I must add others button like «Fermer» or «OK » in Para_Machine.vi? In this case, how I must proceed?
Thank you very much for your help?
I give us the various files which I use.
Nadine
(2,670 Views)
Closing the front panel of a VI does not stop the execution of the VI. In your case, this ensures that your SubVI never completes, and the main VI is not longer able to respond to menu events. The attached VIs demonstrate how you can check for the front panel closing stop the VI.
Scott Y
(2,630 Views)
I cannot view Scott's VI but this should be doing the same job!
Happy trying!
Cheers!
ian
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,618 Views)
