Question about Format Into String Function
Hi, I make file name using Format Into String Function.
I want to make file name
Date_Name_bio.txt
but Format Into String Function create blank(spacing?)
So, file name is made
Date _ Name _ bio .txt
How can i remove blank(spacing?)??
(5,526 Views)
Accepted by topic author Sangkyu
I cannot see the format specifications. Why are you hiding it?
What would you get if you would replace the "format into string" by a simple "concatenate strings"? Seems to have the same functionality.
Please attach the actual VI. Your picture is not useful to troubleshoot. Could also be a unicode related problem.
(5,523 Views)
Thanks.
I solve the problem by using concatenate strings function.
Smiley Happy
(5,479 Views)
You could also set your format string to be "%s_%s_Bio.txt" and then only have the two inputs (date and name).  I find this a lot easier to read than the giant mess of wires going into a large Cancatinate String.
(5,455 Views)
@crossrulz wrote:
You could also set your format string to be "%s_%s_Bio.txt" ...
Yes, that's what I typically do too in these cases. I bet the original format statement (hidden behind the node, I guess), probably was (%s %s %s ...) and thus included spaces (should have been %s%s%s...). Note that the ":edit format string" helper tool auto-inserts spaces and I guess that's what happened here. (we complained about these automatic spaces in the (very) distant past :D)
(5,428 Views)
