Question About A Specific String Conversion
Hello Reader,
I am converting data from one system to another and that needs conversion of string read from a file. The raw file is in hex format with some spaces. This hex will be converted to a normal readable string.
EDIT
I am getting the desired result but was wondering if there is a better/ direct way to get the same result.
Note: String constant is showing a section of entire text read, "desired result" is correct.
Thanking you,
X
(2,379 Views)
Could you please provide an example of input and output?
Is your input string in binary display format?
Santhosh
Soliton Technologies
(2,367 Views)
Hi Santosh,
Previously attached snippet has both input (string constant) and output (Desired Result). No, input string is displayed in normal format.
EDIT
File is in .txt format and below is how I am reading it:
A different section copied from the text file (Just to show how it looks in a notepad) :
00 00 00 51 02 f0 00 42 15 d0 2f 72 c1 08 00 de
02 f0 00 42 15 d0 2f 8e 8b bc 0b d2 02 f0 00 42
15 d0 2f aa b7 72 17 60 02 f0 00 42 15 d0 2f c6
8a 91 32 78 02 f0 00 42 15 d0 2f e2 44 f9 bf 96
02 f0 00 42 15 d0 30 8a 0c 31 7c 40 02 f0 00 42
Please do not use this for conversion as result will not make much sense.
(2,358 Views)
Accepted by topic author XM43
May be something like that will be shorter:
Using Spreadsheet String to Array and Space as delimeter. You have to remove double spaces first to avoid zeroes.
(2,350 Views)
HI Andrey_Dmitriev,
Yes, this is better! Thank you for the suggestion.
I will be stunned if it can be any shorter. 😄
EDIT: This actually corrected one mistake that I was making
(2,344 Views)
