Query regarding data from Network Analyzer RSZVB to computer
Hi. Sorry for disturbance.
I would like to ask u about the data. I have download RSZVB Measurement Example in LABVIEW from Rohde&Schwarz website. Then, the data from did not appear in the graph. The connection that i have use is LAN cable.
Or the result come up if using GPIB cable?
Did not have any idea.
Need your help.
Thank you very much.
Nurhidayah
Message 1 of 15
(3,789 Views)
I note that it seems that your VISA Resource Name control is empty. Have you configured the instrument in MAX and assigned it a VISA alias to select in that control?
Message 2 of 15
(3,776 Views)
Thank you for replying.
Yes, i already configured the instrument in Measurement and Automation. In labview measurement, i have pressed the VISA resource name.
Then, i have changed the start and stop frequency. After the simulation running, no waveform in graph.
I do not know what the problem is.
Need your help.
Message 3 of 15
(3,765 Views)
Run NI Spy / NI IO trace, save the log and post it. We'll see what is going on there.
Message 4 of 15
(3,753 Views)
I have followed the instruction. Please refer the attachment of Capture1.spy.
Need your help.
Message 5 of 15
(3,745 Views)
From what I see in a log your trace data was transferred correctly and there was nothing wrong. You should also have file C:\Trace.csv on your host computer (open with Excel or text editor) with the frequencies and trace point values.
Unfortunately your screenshot doesn't show the X axis of the graph, so I cannot judge if data X coordinates are OK.
Run attached VI, I changed plot points style and Y axis range so it should be visible.
Milo
Message 6 of 15
(3,733 Views)
Thank for helping me.
I have done simulations that you give, but the output graph is still not there.
can u refer the attachment.
Need you help again.
Message 7 of 15
(3,717 Views)
This is data that i have when doing the measurement. The data is OK, but the waveform is not there.
Need your help.
Message 8 of 15
(3,715 Views)
Hmm, your graph ranges are messed up, I cannot see why. Let's try if graph data are OK. Run attached example - it saves c:\graph_data.txt file on your host PC. Post it and we'll see the actual numbers going into that XY graph
Milo
Message 9 of 15
(3,703 Views)
Thank for helping.
I have done the instructions. Can you refer the attachment. I have measured S11 parameter.
Need your help.
Nurhidayah.
Message 10 of 15
(3,700 Views)
