Qestion about synchronizing the motion and the data aquisition set I/O port MOMO.flx
I use the set I/O port MOMO function to synchronizing the motion and the data aquisition.but there is an error:"The Return Data Buffer is not empty. Commands that expect data returned from the controller cannot be sent until the Return Data Buffer is cleared."
I don't know how to deal with it,can anyone help me?
thank you
Attachment is my program.
regards soslotos
昨天是今天的昨天
明天是今天的明天
今天是昨天的明天
是明天的昨天
(2,531 Views)
Hi soslotos,
It looks like you are off to a pretty good start on your application, but let me give a couple of suggestions to make it easier.
Typically, when synchronizing a DAQ board with a Motion controller it is simplest to use breakpoints, which will send a signal on the RTSI lines when your encoder reaches a particular location. I have included a link to several example programs that demonstrate this process. Using the MOMO VIs might make the application more difficult than needed.
Example Programs: Synchronizing Motion with DAQ
Give this a try and let me know how it goes!
Hope this helps,
Robert
(2,515 Views)
