[QUES] High Speed Serial Software Dependency Tree...
We have a PXIe-6592R card with some 3rd party LabVIEW 2017 software to go with it. I have wrapped this software in a LabVIEW 2017 project which makes an executable and a set of stub VI's in LabVIEW 2012 can interact with LabVIEW 2017 based executable and hence the PXIe-6592R (using TCP/IP calls).
The question is, what is the minimum number of items I need to tick in the "Additional Installers" section that will allow this project to run the PXIe-6592R card, but will not trash the LabVIEW 2012 installation?
For example we have software that specifically uses LabVIEW 2012 and was built with certain versions of VISA, DAQmx, NI Vision and so on. What I don't want happen is I install my media for my LabVIEW 2017 based software and it goes and updates VISA, DAQmx, etc and then breaks LabVIEW 2012. So, ideally, I need an dependency tree for the High Speed Serial Software Driver disc (currently we use version 17.0).
We cannot update everything to LabVIEW 2017 unfortunately.
Thanks.
Christopher Povey
Principle Test Systems Engineer for BAE Systems.
(2,486 Views)
Accepted by topic author ChristopherPovey
Most of newer driver will still work with older version of LabVIEW like NI-VISA... I tested it with LabVIEW 2011.
Benoit
(2,449 Views)
