QNET_DCMCT_Position_Config.vi replacement for Labview 8.6
I am currently in the process of trying to upgrade a QNET DC Motor control experiment from Labview 7.1 to Labview 8.6. One of the VIs used-QNET_DCMCT_Position_Config.vi - has no direct equivalent in the CDs that came with Labview 8.6, and the old version is invalid. I have attempted to replace it with the file QNET_Encoder_1_position_config.vi, but the timing of the simulation is different. Is there another VI file that I should use to change this?
Thank you
(2,869 Views)
I believe in this situation your best resource would be to contact Quanser directly regarding the availability of the QNET VI for LabVIEW 8.6. You can contact them here http://www.quanser.com/english/html/contact/fs_contact.html . If they are unable to help you, we will try our best to assist you with this project; however, they will have the most familiarity with these VI's since they developed the code.
Regards
Doug W
(2,848 Views)
