Q:decorations
I'm a "labview-beginner" and have problems with the decorations on the
front panel. What can I do to place the decorations behind the devices
and not in front of them?
Thanks in advance,
Hans
(2,902 Views)
Select/Click on your decoration of concern, then select the Edit menu, and select or as applicable. Also, you could select your other items and move them forward. To get to an item hidden/blocked by another, use the Tab button to rotate through each item until the right one is selected. Good Luck, Doug
(2,902 Views)
Thank you,
Hans
(2,901 Views)
