Right click the graph's control on the block diagram and create a property node. Right click the node and Change all to Write. RIght click the node again and select from Properties either the combined ZScale->Range->All elements -or- you can individually define 2 property nodes for Max and Min (also under Zscale->Range).
Message Edited by Jonnie 5 on 12-14-2005 03:07 PM
2006 Ultimate LabVIEW G-eek.
