Python node Integeration in Labview
I am trying to call a neural network function of python in Labview 2018 thorough Python node, Python 3.6.0 has installed already. When i execute example of Python node, it works fine. But when I try to run neural network it shows following error.  The same code i was running in labview 2015 by using python intergeration toolkit it was working fine. further I have already installed the Tensorflow version 2.6.0 and Keras 2.6 version as well.
LabVIEW: (Hex 0x687) There was an error in executing the specified function.
Module Path: Path://test.py
Function Name: classifer
Python returned the following error: <class 'AttributeError'>
module 'sys' has no attribute 'argv'
 Can anyone tell me where I am doing the error?
(2,281 Views)
Looks like you have defined an input parameter 'argv' in the module but it is not defined in test.py file.
Kindly share your labview and python code for verification
CLD Using LabVIEW since 2013
(2,277 Views)
import sys
if not hasattr (sys, 'argv'):
sys.argv = ['']
I have already added this line of code in test.py file
(2,269 Views)
Hey,
I am facing the same error . Can you share its solution with me ?Please!!!!!!!!
(2,137 Views)
