Python code with no argumants
Hi, ran the attached python code to read a NRF Sniffer and it works well. I am now trying to use the Python node in LabVIEW to read the returned value. I can't seem to figure out a way to read it without getting the following error "Python returned the following error: <class 'TypeError'> bad argument type for built-in operation"
Any help would be golden.
Aashish M
CEO
TransferFi
www.transferfi.com
(2,797 Views)
Your main() function doesn't return anything, so just remove the string contant from your Python node.
(2,753 Views)
Thank you for the response. Yes it runs without errors when I do that, but I am trying to get a the data returned into LabVIEW, just like when I run it in Python and see the data being printed. What do I need to add in the Python script to get the data in LabVIEW?
Aashish M
CEO
TransferFi
www.transferfi.com
(2,732 Views)
You need to have your data formatted as string....if you are trying to return an object you need to define it or return it as a string using... https://www.digitalocean.com/community/tutorials/python-str-repr-functions
How do you need to return data?
CLA, CTA
(2,728 Views)
Hey thank you for the reply. Looking to get the Data string in bold.
def main():
mySniffer = setup_sniffer()
if mySniffer:
if scan_and_follow(mySniffer):
packets = mySniffer.getPackets()
if packets:
data = packets[0].payload
hex_string = ''.join(format(x, '02x') for x in data)
print(hex_string)
print(f"Received {len(packets)} packets")
# ignore everything till the 17th byte
index_626 = hex_string.find('6261636b790104cc13b4e559b1')
if index_626 != -1:
desired_hex_string = hex_string[index_626:]
print(desired_hex_string)
print("Data after '9b1':", desired_hex_string[26:]) # Print the data after '9b1'
dataString = desired_hex_string[26:]
print(dataString[0:24])
hex_string2 = dataString[0:24]
last_two_bytes = dataString[24:26]
decimal_list = [int(hex_string2[i:i+4], 16) for i in range(0, len(hex_string2), 4)]
decimal_string = ', '.join(map(str, decimal_list))
print(decimal_string)
if __name__ == "__main__":
main()
Aashish M
CEO
TransferFi
www.transferfi.com
(2,719 Views)
def main():
Add  'return decimal_string' to your function in Python and in LabVIEW wire the return type with a string.
(2,706 Views)
