Python Script in LabVIEW Context
Hi ,
I've a python script which writes a file periodically (every 2 seconds) . When I run this python script from command prompt or using IDLE, the file is updated periodically and I can read the file.
But when I run the same python script using  system exec VI in LabVIEW context. It doesn't update the file periodically and updates the file when it got terminated. So because of this I can't plot my data in run-time.
Let me know if there is any other way of doing this.
(3,576 Views)
Set 'Wait Until Completion' input to False.
An alternative would be to create a BAT file of your command, then call the BAT file using system exec.vi
(3,563 Views)
Can you share either
A) the Python script you're using or
B) a similar script that uses the same method to write to file periodically (and so exhibits the same problem)?
GCentralI'm attending the GLA Summit!
(3,507 Views)
Accepted by topic author lvbms
Problem solved as I was not using "f.flush()" and "os.fsync(f.fileno())". After adding this I was able to resolve the issue I was facing. It was not a issue with System Exec. Now I can read the file and plot the data as I need. Thanks for pointing out "Wait untill Completion". I need to set it to false because I want to let the script run and don't want to wait for its completion.
def write_csv(*args):
my_str= str(args[1]) + "," + ",".join(args[2]) + "\n"
#print (my_str)
file_handle = args[0]
file_handle.write(my_str)
file_handle.flush()
os.fsync(file_handle.fileno())
(3,476 Views)
