Python Node
I was used Labview 2019 64 bit with Python Node with Python 3.6.0. 64 bit in Windows 10 64 bit.
I Used tensorflow-gpu=2.5.0 in my python code and that python file run in labview with pyhton node.
i get below error when run python node.
??? in DL_Main_Window_4.vi<APPEND>
Module Path: D:\Projects\Python Projects\M1.py
Function Name: load_Cmodel1
Python returned the following error: <class 'AttributeError'>
module 'sys' has no attribute 'argv'
<traceback object at 0x00000246CD7BE808>
Call Stack information:
['Traceback (most recent call last):
', ' File "D:\Projects\Python Projects\M1.py", line 3, in <module>
import tensorflow as tf
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\__init__.py", line 49, in <module>
from ._api.v2 import __internal__
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\_api\v2\__internal__\__init__.py", line 13, in <module>
from . import distribute
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\_api\v2\__internal__\distribute\__init__.py", line 10, in <module>
from . import combinations
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\_api\v2\__internal__\distribute\combinations\__init__.py", line 10, in <module>
from tensorflow.python.distribute.combinations import generate
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\python\distribute\combinations.py", line 37, in <module>
from tensorflow.python.distribute import multi_process_runner
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\python\distribute\multi_process_runner.py", line 39, in <module>
from tensorflow.python.distribute import multi_process_lib
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\python\distribute\multi_process_lib.py", line 60, in <module>
if _is_enabled():
', ' File "C:\Program Files\Python36\lib\site-packages\tensorflow\python\distribute\multi_process_lib.py", line 39, in _is_enabled
tpu_args = [arg for arg in sys.argv if arg.startswith(\'--tpu\')]
', "AttributeError: module 'sys' has no attribute 'argv'
i was already set all environmental variables as per requirements. But can't get success to run my python file with python node.
also noted when i used Intregrated Python toolkit that time same python file runs well any problem but when  used python node that time above error occurs.
(2,228 Views)
https://stackoverflow.com/questions/30343225/how-to-handle-errors-related-to-sys-argv-in-python
You try to call a module that expects an argv argument being passed to but don't pass that in.
Rolf Kalbermatter  My Blog
(2,220 Views)
See My python code and Labview Code.
I was install python 3.6.0 64 bit in windows 10 64 bit.
tensorflow-gpu version 2.5.0
(2,217 Views)
